Make Offer - Parts!!!
Street Tracker
Dirt Track Mentality
Arroyo Grande Ca
have quite a few things left swing arm axle pivot bolt, axels, foot pegs, 650 Central Epo’s and Tpo’s, Emgo high output coils, top motor mounts, drain plugs, stock fork inner parts. Rotors and foot pegs and forks sold. If you you don’t see something I will look and all is make offer and shipping on you however you want it.
Yes I have a Hugh’s clutch lever with master and slave cylinder & cable and new cable unwrapped never used. Think I have a front axle and I know I have a complete rear axle and nut with adjusters. I don’t know about spacers.
Okay I have rear axle nuts and adjusters, front axle, Hugh’s full clutch set up one slightly used cable and banjo bolts and seals, plus two more cables and fittings never been used. Say $ 100 plus shipping say $ 20 usps. Let me know and I should be able to get it out tomorrow.
How's the rubber on those front footpegs? The splines on the gearchange lever?
Foot pegs are gone and have two shifters stock and spines are good not bent rubber a bit old, also have the MikeXS extended brand new never used.
I found a front caliper and 3 extra pistons for them, one rear axle spacer and the front axle center spacer and end spacer. Threw those in there add any cash you want is fine bud. All boxed again and ready to go!
