1. Dismiss Notice
    Dismiss Notice
Period electrical connectors
Discussion in 'The Garage' started by RC4MAN, Nov 19, 2019.
  1. RC4MAN
    RC4MAN XS650 Enthusiast
    75
    102
    33
    North GA
    Anyone suggest a source for correct period electrical connectors for the various year models.
    I did a cursory search on google and found 4-5 various possible sites listed which I haven't had opportunity to wade through the various ones by brand and year. Curious if someone can suggest source for specific '73 Yamaha stuff.
    Thanks
  2. 5twins
    18,501
    8,901
    688
    I ordered a couple kits from this place, Vintage Connections. I got one for bullet connectors, one for multi-terminal blocks, and their crimping tool .....
    http://www.vintageconnections.com/Products/Kits
    I also re-use lots of connector blocks I "liberate" from old harnesses. In fact, that's my first "go to". If I can't find a suitable used connector in my stash, then I'll use a new one.
    My bikes are '78 and newer but I don't think there's much difference in the connectors. Maybe many of the newer ones are latching types whereas the older ones may not be. The multi-connector blocks fit so tightly together, I really don't see the need for the latches.
  3. Downeaster
    Downeaster Everything in XS Top Contributor
    +1 for Vintage Connections
    peanut and RC4MAN like this.
  4. mrtwowheel
    mrtwowheel Honda Etched On Brain Top Contributor
    Measure the size of your bullets and blades before ordering.;)
    gggGary and RC4MAN like this.
  5. aldo5468
    aldo5468 Redleg XS650.com Supporter
    www.cycleterminal.com
    RC4MAN likes this.
  6. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    +2 for Vintage Connections. Quality products and quick shipping.
  7. peterg
    peterg XS650 Addict XS650.com Supporter
    352
    309
    63
    Canada
  8. These are not period correct but I use these on my harness builds and some do match up to stock connectors . Way less money you guys are spending and they work well. If you are going to change one side why not both? They also come in other sizes.
    RC4MAN likes this.
  9. RC4MAN
    75
    102
    33
    North GA
    Thanks, actually that's an option that just may work for my build as I'll mainly be using them for accessory hook ups to the existing harness as I no longer have the original lamp assemblies.
    Since there are no longer any Radio Shacks around.
    You have a source?
  10. 5twins
    18,501
    8,901
    688
    EBay, there's tons of that stuff on there. I bought some to supplement my kits but the quality definitely isn't as good as the kits. But, if it's something you won't be plugging and unplugging often, they work fine. In particular, I got female spades that included the soft plastic insulation covers. Those hard plastic insulators that come on many crimps just plain suck. I won't even use them, I cut them off .....
    https://www.ebay.com/itm/100pcs-6-3...491652?hash=item2889236b44:g:LeEAAOSwnhpd0i~O
  11. mrtwowheel
    Those won't lock into a plastic block, but used as a single connection, good deal with those plastic covers.
Share This Page
