Seeing how a dc motor and a dc generator are physically one and the same, would it not be theoretically possible to lock the starter gears into permanent engagement and use the rotating motor armature as a permanent magnet generator without modification? Of course you would have a kick only machine at that point, and I'm not sure how to regulate the output since I think most PMA regulators toggle the ground.
I am thinking you would have a single wire 13.5v positive output. The motor is rated to 500w I believe. Would that directly translate into a 500w generator?
Big questions:
Could the motor take the rpm?
Would it run cool enough to survive?
How long would the brushes last? Although they seem to last just fine on older attraction/repulsion type electric motors.
Would the output be dc or ac?
I seem to remember a DT125 that used to use its charging system as the starter as well, or I may be misremembering.
Anyone with a lathe and some free time willing to give it a whirl (literally)?
Big questions:
