1. Dismiss Notice
    Dismiss Notice
Wanted - Petcocks
Discussion in 'Classifieds' started by AndersJ, Nov 29, 2019.
  1. AndersJ
    AndersJ XS650 Enthusiast
    Need R and L non vacuum petcocks for my tank. Let me know if you have some laying around. Not too worried about condition, but preferably somewhat functioning.
  2. Machine
    Machine Race the wind Top Contributor
    This is a near new MikesXS non vacuum petcock not being used. This is a left which came off a 79 Vacuum petcock equipped tank.
    Hole spacing is approx 1.800"
    Keep it in mind?
    Vancouver USA
    -R
    nj1639 likes this.
  3. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Just need to point out that you need to know either what year the tank is - or the spacing of the petcock mounting holes.
    XS650s were built with AT LEAST two different hole spacings - and the wrong petcocks will be totally useless to you.
    Pete
    nj1639 and AndersJ like this.
  4. AndersJ
    MaxPete, I appreciate the heads up. I do know the exact year, but it has the offset gas cap, and is the one pictured in my "new member post"
    Measured with calipers and looks like 1.8" center to center would cut it. How vast were the spacing differences just out of curiosity?
    Machine, I will keep it on the radar. Trying to get this bike running as cheaply as possible so that is a factor as well.
    nj1639 likes this.
  5. Spacing difference is just a couple of millimeters, just enough so as they wont swap. '77 had the smaller ones, '78 and newer all seem to be the same (longer) from what I've come across.
  6. grizld1
    grizld1 Grumpy old man Top Contributor
    Center-to-center spacing is 42 mm. to 1977 (manual operation), 46 mm. 1978 forward (vacuum operation). For an easy conversion of vacuum petcocks to manual operation, cap off the vacuum line barbs at the carb boot and the petcocks, use the run or reserve position to shut off, and turn the levers to prime to turn on the fuel.
  7. AndersJ
    just measured and 46mm is the ticket. Does this mean I must run the vacuum petcocks?
    MaxPete likes this.
  8. Jim
    Mikes has the non-vacuum's with the 46mm base. 30 bucks per side. Look here. I've never used 'em so I can't vouch for the quality.
  9. AndersJ
    Thanks Jim! Saw those, but $60 for two petcocks of unknown quality seems high...
    Jim likes this.
  10. Machine
    Looks like the one I posted ?
    This left could go in a $8 USPS envelope.. so free. Find a Rt. Match anybody ?
    -R
    AndersJ likes this.
  11. AndersJ
    Machine, I'm looking at an 80's basket case tomorrow to see if I can't find a set. But if not I'll PM you about the one you have.
    I've never had a vacuum petcock on any of my bikes, are the repairable/reliable?
    Anyone else need any parts while I'm there (a super ugly king and queen seat for example!) looks like a complete bike...
  12. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
  13. Jim
    I rebuilt mine using OEM parts and a Viton seal I sourced separately. It's pretty easy to do and so far (this summer) is holding up just fine. I bought Mikes rebuild kit but I didn't like the quality. Only down side is that the OEM parts cost around 30 bucks.
    gggGary and AndersJ like this.
  14. Machine
    I run stock Yamaha Vacuum Petcocks of this series. 78/79 Standard model. These have been very reliable on 3 XS's and counting on a 4th.
    The Mikes XS petcock offered appears to have little or no use IDK but I have what I need.
    -R
    gggGary likes this.
  15. I picked a couple up off of Amazon, looks to be the same as Machine showed in the first pic, around twenty bucks a pop. They swap left or right by changing the inlet side and plugging the other....either / or........of course the lever doesn't switch for shut off, which is 9:00 position either side. Just remember "down" is on.............lol
    Edited for dyslexia moment......
    AndersJ and Machine like this.
  16. Machine
    Sending one of these to AndersJ
    In Utah. Its a MikesXS lft or rt switchable apparently.
    He will need one more for the set..:thumbsup:
    Anybody?
    -R
    nj1639, Jim and AndersJ like this.
  17. AndersJ
    Thanks again Randy!
    1 piece closer to getting this beast on the road.
    Machine and Jim like this.
  18. grizld1
    Late Special tanks use only one petcock to feed both cylinders. I once drained an early Special tank through the left tap, then opened the right to see how much fuel remained; it was about 4 oz., not enough to reduce range significantly. If you want to save a few bucks you could cut a plate from 1/8" aluminum stock, drill holes 46 mm. apart, and cut a piece of gasket material to match.
  19. AndersJ
    There is a chance I'll end up making such a plate to seal the tank while I'm cleaning it anyway.
  20. scrapmetal
    scrapmetal XS650 Addict XS650.com Supporter
    Hi
    have a bunch of these original Petcocks, came from the TX750, left and right, all apart with no gaskets,
    are this the ones you looking for?
Share This Page
