PMA Install- Burnt stator
I just installed a PMA, I used a ZX600 stator and reg/rectifier per the how-to by hugh on this site. I used banshee flywheel, plate and Hugh's adapter.
http://www.ebay.com/itm/281073996454?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
At idle I reach 17.8V (ish) and under throttle get all the way to the mid 19s! I assume bad regulator but want to check my steps first.
In the link you can see it's a 6 wire reg/rect, I just ignored the brown, I think it's for some sort of "swithced on" components. I wired the red (pos) and black (neg) directly to my battery posts. Eventually I will run just a sparx capacitor but wanted to test on battery first.
The other (smaller) issue is that I can no longer get my headlight to turn on. I yanked the stock regulator, rectifier and safety relay. I thought I may need the safety relay to engage the headlight so I plugged it back in, not bolted assuming it's not grounded to frame. Still no headlight.
Anyways any other way to test this regulator? Any way I can swap in a different reg/rec to see if that's the issue? I have a dr650, if the components are super genenric perhaps I can do some local swapping before dealing with shipping junk around. Thanks
Posted via Mobile
Posted via Mobile
