Yes, there will be times when both points sets are open at the same time. Each set of points will close for a short time during every engine revolution, for about 90° or 1/4 of that revolution. Your points cam looks fine.
Thanks man ya it was back Firing and popping in the carbs all over the place and barely wanting to run I spun the whole entire assembly to the left a quarter of an inch in the thing runs amazing now I don’t have a timing light or anything I’m just going off of when it will start to run i need to get one
Yes, you do need to get a timing light. Correct timing is critical on these if you want it to run as well as possible. There's also the possibility of holing a piston if you run the timing too far advanced.
