kevith
Hi everybody.
This is my first post here after enjoying all the knowledge gathered here as a reader only.
I´m 56, live in Denmark EU, and rode an XS 25 years ago. Now I´ve picked up one again, a ´77, and has done an intake rubber and cam chain change. I´ve put it all back together, and all I need to do now is adjust valves and ignition.
And here´s my problem: When I try to set the ignition timing, everything is WAY off. I´ve set both points to open 0,35 mm. So now I´m to set the timing with the backplates. I use a piece of Rizla cigarette paper to determine when the points opens. In the old days that used to be fine to get it running, and then fine adjust with a timing light.
But when I try to set the timing, I can see, that the points for the right cylinder opens half a revolution before they should, when the timing mark on the rotor is opposite to the F-mark...!
I really can´t see or figure out what I did wrong. Is there any one here, that can?
Thankas
Thankas
