angus67
Welder's penetrate deeper!!
I was noticing on my points that the block that rubs/rides the eccentric for the points isn't getting lubbed, because my felt isn't touching the eccentric.
is it felt? what lube to use?
I also noticed 3/4 of the rotation ,the rub isn't even touching the eccentric, but points open as they should, bike runs fine. Does it have to rub the full rotation? looks like the rub block on the points is a little smaller than I remember. wondering if its melted. points weren't that far off. I think the plug was just fouled. I hit it with a soda blaster, and fired up.
had a hell of a time trying to start it the other day. reset the points, cleaned plug, fired right up.
I know y'all love pics of anything as much as I do, still want to see?
Side: very small arc sparks from points when running--normal?
I know big sparks are bad. bike doesn't miss, new condenser, new coil.
