Points to GN250 Electronic Ignition Conversion
Well this is interesting...
Here's the sensors I picked up based on @Team Junk 's recommendation. Don't recall what they're for. I'll add that info shortly. These sensors are a magnetic, 400Ω coil. I'm still not completely convinced having a magnetic coil as well as a magnetic target on the rotor is the ideal setup. The one on the left is as made (wires added by me). The one on the right is one where I bent the mounting legs straight, trying to come up with an easy way of mounting it.
Anyway.... I got to fiddling with it and discovered it can be disassembled... and pretty easily I might add. Disassembled it by hand using no tools. As you can see here, the magnet and iron core can be separated from each other.
So what you see stuck to the magnet on the rotor is a non-magnetic coil.... just like the TCI sensor (which we know works). The TCI coil is 700Ω's and this one is 400Ω, so I'm not sure what kind of power it'll generate. I'll dig out the twirly bits I used before and see what we get.
As it came, figuring out how to mount it was bein' a bear... couldn't figure an easy way. Now, making a mount for it has become much easier. It's a whole new ballgame now boys and girls. Stay tuned.
EDIT: Here's the coil. $7.49 on Ebay
I've got some baseline values to work with now. Not really sure what to make of 'em :umm:... but all I need 'em for is to compare them to the sensors I try going forward. These are based on the stock TCI pick-up and magnet... which are proven to work with the GN250 box.
250rpm. Startup speed... or thereabouts.
1500rpm. Idle.
3100rpm. Full advance (scope amplitude reduced)
The O-scope app I wanted to use is no longer available. I'm still working that out.
Put the honeydo's on hold to spend some time on this.
Here's my plan; modify the existing stator so that it will accept a TCI trigger as well as whatever I come up with as an alternative. Can some of you lads look this drawing over and tell me if that's enough info for the average joe to modify it? Thanks.
Hi perhaps
I have worked with sheet metal in the past and some on construction sites
The markup of the holes to drill perhaps could be marked with a Compass ( as to draw a circle )
Going from the existing mounting holes from the right hole the radius 69 mm
and then do the same thing from the left mounting hole a measure that you perhaps are kind enough to provide
Those two arcs will then intersect in a crossing ..the drill point
Perhaps that will be simpler standing on Your Knees. So to speak under the streetlamp
Perhaps a paper template that can be printed out in 1:1 scale with the hole points
Fixating the paper in the mounting holes ..and then markup according to template .
For example with Punchmarks .. and then drill and thread ... Something then also possible to do under the streetlamp
If one is careful getting the holes straight
Thinking out loud would not a slit on the upper mount be an advantage ..giving some room for adjustment.
I have not read all so Apologize if this is not Possible.
Tested the Yamaha RXZ magnetic pickup. This little puppy is wild. At 1500rpm and a .025" air gap, this thing cranks out 1.32volts. :yikes:
Couple other things jumped out at me... for one, it's a lot noisier than the TCI pickup. Also, the top and bottom of the trace is chopped... not sure why?
Took the air gap all the way to 0.1" and it was still puttin' out close to a volt. I'm thinkin' magnet on magnet isn't the way to go?
Interesting - an output of 1.3v would be pretty high as a trigger wouldn't it?
Well Pete, this ain't my specialty... so I'm kinda in uncharted waters here. I think that is too high. I'd guess we need to be more in line with the TCI trigger since we know that works. Tomorrow I'll try the same pickup with the magnet removed and see what we get.
What we're doing here is develop a low cost alternative electronic ignition system for the 70 to 79 XS650. While I’m sure this could be adapted to other engines, our focus will be the XS.
Goals:
View attachment 173555 Crankshaft Triggered. All modern engines employ a crank triggered system because it’s inherently more accurate and stable than a cam triggered system.
View attachment 173555 Low Cost. Under $50 is the target. The Suzuki GN250 box can be had for about $20. The trigger coil comes in under $10. Other misc parts will bring us close to out mark.
View attachment 173555 Built in Electronic Advance. No moving parts means maintenance free.
View attachment 173555 DIY. Design a conversion that’s easily done by your average backyard wrench using nothing more than hand tools and a drill press.
View attachment 173555 Step By Step. Instructions laid out in a logical, easy to follow sequence.
View attachment 173555 No Loss in Performance.
cont.
Not sure I understand it ..but for having the electronic Gonzo box one needs a magnet in the rotor
( if I understand it right ) # 26 here
Inserting one is difficult and risky . Getting the old rotor off .One needs a tool
And the hole for the magnet must come in the right position in relation to the TDC ..via the Keyway or markings
That is not a job done under the Streetlamp ..Standing on the Knees .. That everyone can do themselves
A replacement costs 160 Euro ca $ 190
I doubt it is cheaper to take it to a mechanical shop here. Let them drill ..
I have rewound 2 rotors neither costed less than ca $ 100
https://www.xs650shop.de/en/electric/1099/alternator-rotor-70-84-exchange?number=24-0060
My Boyer has the pickup and magnets on the camshaft end I believe two of them. Each
Even though it is perhaps not a perfect solution it does not involve removing or drilling in a expensive Rotor
that is prone to break when handling it.
Cost wise if I am not lost here .It appears to reduce the grand total cost if the pickup was on the
Cam shaft end. On the earlier models that does not have a magnet as it seems.
Even if it means some more electronics for the signal.
Again I feel a bit sorry for mentioning this since the job done is important .Those Pick up signals I believe someone needs
further on.
I have worked with product development ..generally speaking the sooner the better. If existing not imagined problems
Are mentioned.
A solution can be found .Perhaps it is simpler for you in America to do what at this point in time seems expensive here.
Low Cost. Under $50 is the target. ---- the Rotor job tends to crash that by a factor 2 X
Am I Wrong ???
Am I Wrong ???
Yes, you're wrong. Have a read here Jan. Eventually I'll move some of that info over here. Until then, bear with me... there is a plan.
The clipping on that one wave will probably go away if you set volts per division higher. Or there might be something to set on the display. The high output means you might be able to adjust timing by moving the pickup in and out, since shrinking the wave effectively changes where in the rotation it crosses the voltage threshold to be detected, depends on how pronounced the ramping up is. Magnetic pickup probably means you can use a steel washer attached to the rotor instead of a magnet. If you want to limit a too high output, a voltage divider look up voltage divider formula, will lower the amplitude without affecting the shape.
If the output is high enough and the ramp slow enough and my theory about amplitude effect on timing is right, then instead of a voltage divider you could use a trim pot wired like a divider and fine adjust the timing by twisting its knob
