MikeC23
Good morning all. First off I did read the carb guide! I feel like I should throw that our before my question. Ok. On to the question. I decided to rejet the carbs on my 79 special. They were stock BS38's. I had put on UNI foam air filters. I went up one on the mains (to 140), down one clip from stock on the needle, and one size up on the pilot (to 30). Is my assumption correct that I now need to adjust my air mix screws to be leaner than factory (2.25 turns)? OR should I set them to factory and balance with a manometer from there? Those mix screws are the only thing I'm having an issue finding info on.
Thanks!
Thanks!
