I guess the only true test will be once it's running. Plunk it in 1st and hope it doesn't lurch forward and stall the bike. If you've read through some of the clutch threads then you know it isn't the greatest on this bike. Sure, it works, but it has lots of drag and that can make for stiff shifting and hard to find neutral when hot. The problem is barely adequate plate separation and that gets worse as the bike heats up and parts expand. That's why most of us adjust the clutch quite snug cold. That way when it gets hot and parts are expanded, it still continues to work acceptably. You won't find neutral as easily as when it's stone cold, but you can live with it.
And speaking of the stiff shifting, something you'll want to routinely check is the tightness of the shift lever. It gets loose on the shaft splines quite a lot and will require tightening. Sometimes you can't get it tight enough. The 2 halves of the split in the side will touch before it's tight on the splines. That will require a little filing of the slot to make it a bit bigger. You don't want to run it loose, that can eventually strip the splines.
