Howdy!
We are having a chat about tools on the ST Owners website and I joined in (I
like tools) and wrote a note about some issues which I thought might be of interest to the XS650 group as well.
Have you ever noticed that some socket sets do not come with certain size sockets.
In most engineering design work there are "
preferred" sizes which most designers select. Moving off those preferred sizes is discouraged because the cost of components goes up dramatically - for virtually no added functionality. For example, most Imperial fasteners normally come in 1/4" increments of length. So, you will find 1/2", 3/4". 1", 1-1/4" and 1-1/2" long bolts easy to find. Just try to find a 1-1/8" long bolt (in ANY size) and you'll likely be stumped. The fastener manufacturers will be happy to make them for you - but they'll charge an arm and leg for them, so you would need a pretty compelling reason to select that length in a given application. The same goes for almost any standard item such as seals, bearings, I- and H-beams, roll pins, etc.
On the issue of hex sockets, in my work we normally would select a bolt with a 13, 15, 17 or 19 mm hex head whereas on the Japanese bikes I own, a commonly used sizes seem to be 12, 14, 16 and 18 mm. As a result, I have had to buy a selection of 12, 14, 16 and 18 mm hex sockets in shorty, medium and deep with 3/8" and 1/2" drives to suit my ratchets. The same goes for open and box-end wrenches (
aka spanners) and many other items in the mechanical world. I guess the preferred sizes in Japan are 12, 14, 16 and 18 mm rather than 13, 15, 17 and 19 mm - but as noted above, the square drive sizes are the same everywhere in the world (thank goodne$$).
There are other differences in hardware and tools in various countries.
In Japan, they have adopted the JIS (Japan Industrial Standard) screw head design that is used on our Yamaha bikes, as well as on
ANYTHING else built in Japan. The JIS is a much better design than the Phillips even though the two seem identical at first glance. If you are working on an XS650 (
and who on this site isn't) you would really benefit from getting yourself a set of JIS drivers. They are not expensive or hard to find - just look on eBay for "Vessel" brand JIS screwdrivers - and be sure to include the big #3 silver-handled "
Impacta" driver which is perfect for removing the usually f@cked-up clutch basket screws.
In Canada, we use Robertson screws for anything wooden like boats, decks on houses, furniture etc., for electrical panels and house wiring or for self-tapped metal construction. Conversely, this type of fastener is pretty rare outside of the country. I think in the US, they are known as "square drive" screws but they're not often used. I must say, the Robertson is also much superior to the Phillips because the fastener won't strip and can be loaded onto the screwdriver and it won't fall off which makes one-handed installations
waaaay faster and easier. Robertson drivers are not expensive and are available at any hardware store in the country in a wide array of lengths and styles including 1/4" hex-drive bits for use in screw guns.
Also, there are only four sizes of square sockets in the heads of Robertson fasteners and the matching drivers are always colour-coded so that you know which one to use. They go in order of size:
yellow,
green,
red and
black and so it is always easy to pick the correct one out of a crowded toolbox. In Canadian house wiring, every single ground screw inside a box is a "
red" size and every single terminal screw on a device such as a receptacle or light switch will be a "
green" size Robertson - which is convenient because it means that you can do this work with
very few tools in your tool-belt.
When I was a service engineer for a Toronto-based company that built big injection molding machines in the 1980's, our electrical panels were assembled with Robertson screws and the personnel at our customer's US plants absolutely hated that because the service people couldn't easily find tools and replacement screws. I started packing a few boxes of common size screws and several sets of screwdrivers with me on business trips and boy, can you ever make a friend fast by giving a mechanic a new tool - especially one that is a bright colour and sort of unique. Within a few weeks, it was noticed by management that the operational "up" time of our machines soared in those plants and we figured that it was simply because the service folks liked working with their odd-ball new screwdrivers.
The square drive screw head was invented much earlier by Cummings in the US, but it was patented, commercialized and named by P.L. Robertson near Toronto around 1910. Henry Ford used them to assemble the bodies of the earliest Model T automobiles. Henry calculated that use of the Robertson screw saved
two hours of labour in building each of his cars and so he wanted to actually buy the design and patents from Robertson and have an exclusive on the new type of screw. However, Robertson wouldn't sell and simply wanted to supply screws and drivers to Henry - but Ford wouldn't agree to that arrangement and so that is why the US auto industry adopted to the inferior Phillips screw subsequent to about 1912.
More recently, the auto industry has adopted the Torx head which shares many of the benefits of the Robertson, but is much more costly to make.
Sorry to get so far off-topic from XS650's, but I do like tools and hardware.
Pete
