Problem mounting Old School Speed Mid Controls
PickleSlice
Lakeland, FL
I'm having some issues mounting the OSS mid controls on my '78.
Pictures attached. I got these off of eBay and as far as I know, they are supposed to be bolt on and go. The peg folds up for kicker clearance, that works fine. The problem is, with the kicker fully kicked, it engages the rear brake. I think that this would "work" but it can't be by design. I've tried many different configurations, but can never get it to work.
Anyone have any input on this?
No experience with those, wish I could help. With that brat kit I can't imagine that's gonna make for a comfortable riding, you're a tall guy. Maybe I'm wrong, just something to consider.
I've seen some rear and mid set builds on here that use different kickstarters to solve clearance issues.
Creative searching could find those...
I'm 5'10" or 5'11", depending on which convenient store I'm leaving. Sitting on it in parked, it feels pretty comfortable, but I have not gotten rid of the stock controls just in case.
I did quite a bit of searching, but these specific controls do not seem to be very popular. I'll do some more generic searching to see if I can find anything pertinent.
I had a similar issue when I did my Cafe Racer build. I cut and rewelded the kickstart to clear the foot controls, then had it rechromed
Despite being cast it welded without issue
Hi 'Slice,
try lowering the brake pedal by adjusting the threaded shaft out a bit?
And straightening the brake pedal's S-shape a tad so it ends up under the kicker body rather than under it's swing-out pedal?
It looks doable from the photos, anyway.
Hi 'Slice,
I've been thinking about it all day today at work, and I think I can cut and drill the stock brake lever to make it work. I think that curved one is intended to go around stock exhaust. Thanks for the thoughts!
I found that when it was installed like shown in this pic, the kick start lever did not depress the brake arm and apply the rear brake as it rotated downward. Try loosening the brake adjustment up totally, match the angles in the pic, then re-set the brake adjustment so it engages fully when you step on the brake lever.
How hard does it hit the brake pedal? If it isnt bottoming it out, no biggie. You supposed to be stationary using the kicker anyways. Lol. My dirt bike floods easy, thank god I have a hill to start it.
