Quilty
Hello guys I'm new to this forum. I joined because I've seen a lot of good advice so far but I am beginning to have problems with a restoration I'm currently undertaking. So I'll begin. I have just bought a 72 xs2 and I'm pleasantly surprised how easy it is to work on compared to a harley. Anyway I've taken the carbs off to see what the way previous owner has set it up. There's a 125.5 main jet 42.5 pilot and a 125 butterfly plate correct needles and gasket, slides diaphragms and needles are all in good shape. They just needed a bit of a clean up so I got some petrol out of the tank and proceeded to clean. Carbs back on the bike, tried to tune using dead cylinder method left plug fine but ran hot and sooty right plug cuts out and runs cold out of the exhaust. Also no idle screw response at all on the right. I'm guessing the left cylinder is running at 1000 ( hence the soot on plug) and the right isn't however they both seem to be firing. Also I should mention that a tug of the individual butterfly on the right gives a stuttery and boggy response
I'm gonna swap the mains for 130s as stock but I'm at a loss each carb is set/ tuned to factory spec execpt for the main jet and needle at no3 pos not no4 can anyone help
