Hi,
I'm newer to the site and to owning an XS650. I have an 83' Heritage Special and trying to get the clutch to engage. I adjusted the adjusting screw on the outside of the casing, however, it seems that the push rod is still not engaging. When I was replacing the clutch cable and took the casing off, I noticed the push rod fell out as well as the ball bearing. i put the ball bearing and the push rod back in, however, now the clutch does not engage and the clutch hand lever is hard to pull back. Any suggestions?
Zach
Zach
