skrapper
when i do brakes on a automobile i use a c-clamp to push the fluid back into the M/C. on my 77 xs 650 when i try to squeeze the fluid back to the M/C all that happens is the lever get really firm i can hardly pull it at all. shouldn't the fluid come out the little hole in the bottom of the M/C. i tried to clean that hole out with a small drill but all i get is clouds of rust. i just need to know if the fluid is supposed to return through that hole.
thnx skrapper
thnx skrapper
