TeeCat
One-Mik Wonder
Guys...
There is an existing thread on this topic, which I have read with interest, but I didn't want to commandeer it, so I thought I'd reference it instead.
For the first time since I have owned my bike - and just after having gone to winter-weight synthetic, interestingly - I have discovered a slight oil weep right around bolt #5, at the gasket between the cases and the pot, left rear corner as you sit on the bike. It seems slight, but it's also new, I think. But the timing (cold temps ad light weight oil) is interesting.
I have never been into this motor myself, but can't swear that a PO has not. I have never, therefore, torqued or re-torqued the bolts. That said, I'm not sure if I should just keep an eye on it (I ride very little in the winter) and see if it clears up when I go back to 20W-50 (synth, as the bike seems to like synth otherwise), attempt a re-torque of the affected bolt(s), or attempt a full re-torque. I have never done it before, but I suppose I would if needed, and just take my time and do it carefully/correctly. I just don't particularly want to disturb a motor that otherwise seems to be running like Flo-Jo.
Thank you!
TC
Thank you!
TC
