bdholsin
XS Enthusiast
Real quick question on my BS34 carbs. I recently cleaned the hell out of them. Stripped the black paint off and reassembled (properly I might add). I'm having a little issue with fuel pouring out of the right hand carb. I know for a fact that my floats are both set at 22 mm. I just did that today. However, I'm still tinkering with the mix screws.
Here's my question: if I have the mix screw on one carb (the right hand one in this case) backed off too far would that allow fuel to flow more freely into the carb bowl and subsequently pour out of the back of the carb? I believe it is coming from the jet in the lower left hand side of the face (as you are looking at it from the perspective of the air filter).
I just got back from a quick test ride and it did this. I had the mix screw at 3 1/2 turns. Brought it back to about 2 1/2 turns and it seems that the fuel has stopped flowing out of the carb.
I realize it could be the o-ring in the needle valve seat but I just replaced it this weekend. There is the possibility that I nicked the o-ring or that it was damaged from the get-go. However, the mix screw adjustment fix leads me to believe that it isn't the o-ring.
Am I going in the right direction here? Thanks guys.
