mule
Radian swing arms (2). These arms were purchased for $190.00 each. Then I had them sandblasted, I ground off the original shock mounts, hand made bigger stronger ones that take a 3/8" shock bolt, welded on the new mounts, had the axle slots lengthened and enlarged to .750" to tale a bigger, stronger axle, bored the chain adjusters to match and then powdercoated the arms silver with a clear coat. I cleaned them up after P/C, installed brand new bearings and seals, polished and clear anodized the chain adjuster plates and fitted 3/8" Grade 8 shock bolts that have the heads dished and were then CAD plated. If I get $425.00, I'll break even on money spent and these things look bitchin'! They are show quality. Axle not included. I also have a bunch of stock 650 stuff I've replaced with upgraded parts from several projects.
