Radian swinger width
- the XS axle is a little shorter, about a half inch if i remember correctly
- also the radian axle is 17mm, the XS is 20mm
- the radian swingarm is also a little longer which will alter the steering somewhat, slower
- may have to alter the rear shock mounts a little
- if running rear drum make sure the drum plate brace lines up properly and isnt tilting the brake plate
- all in all a tidy and relatively easy conversion, stronger and lighter
Thanks inxs. I had found most of that doing some research. I Dont want too much longer of a swingarm as the front end I'm plannng to run is going to reduce trail a bit, so I dont want to go too much longer and take even more trail out. I've gotta get it on my bench and start taking some numbers so I know right where I wannna be. But that's not my issue right now.
What I'm trying to find out is the width of the radian
swinger, inside to inside, at the axle location.
