Jon M
My '78 XS650 has a rattle that sounds like valves but they are adjusted correctly. I've checked the cam chain tension and it seems to make no difference. The rattle is louder when the engine is hot, maybe just because the oil is thinner. It's most noticeable when the engine is not under load. I think it is very slowly getting louder (over the months I mean) and I plan to do some longer trips this year so I figured it was time to resolve it.
I deduced that it was the front cam chain guide so pulled the engine. The front guide looks fine, in fact I think the PO already replaced it - he told me he rebuilt the engine about 15,000km ago but I'm not sure exactly what he did.
The rear tensioner/guide looks ok but the rubber part is quite grooved. Is this a problem? Also, is there a way to tell if the cam chain needs replacing - could a slack cam chain be the source of the rattle? I'm not sure if it's the original chain - the links are stamped with 'Japan' and 'EK29 H' - anyone know if this is OEM?
There is a small amount of metal in the oil - seems to be sticking to the magnet.
Any suggestions on what else I could check re the rattle while I'm in here?
Thanks!
[/URL][/IMG]
[/URL][/IMG]
Thanks!
[/URL][/IMG]
[/URL][/IMG]
