1. Dismiss Notice
    Dismiss Notice
Re-thinking my rear brake.
Discussion in 'The Garage' started by thuban, Oct 18, 2020.
  1. Machine
    Machine Race the wind Top Contributor
    thuban, the cam shaft mark is the original..
    Its supposed to be forward :umm: turn it around. That's what I remember and have done
    TwoManyXS1Bs, thuban and gggGary like this.
  2. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Thuban
    Couple of questions.
    What kind of brake shoes did you use? OEM or aftermarket. It could be the linings are so hard they don't create enough friction.
    Is the peddle firm or spongy when applying the break?
  3. thuban
    thuban Horse Scratcher XS650.com Supporter Top Contributor
    Machine, I put those marks there. It had none. Bike was a one owner, brother-in-law. He was not a mech. All work was done by a shop. Shoes were original Yamaha. It had 14K miles on it when I got it. I think the front and rear tire were original also. ( There around here someplace) Could a shop have gotten the cam in wrong and then I marked it wrong? Yes. But I won't know that until I pull the wheel and for that I'd have to pull the RH peashooter. So I'm going to wait until the rear wheel has to come off to check the cam.
    GLJ, Spongy, like your stepping on a big spring. Pretty sure brakes are after market from Mikes. I marked the arm exactly in the spline. I think you can set the arm anywhere you like but that is where everything was when I took it apart. Could be those shoes. I'll cabbage onto an OEM set and I'll have them when needed.
    gggGary likes this.
  4. 5twins
    20,183
    12,265
    813
    Yes, the dimple on the cam looks original, the one on the brake arm was added (by you?). It's assembled wrong, even if that's how it was to begin with. It was wrong to begin with, lol. Like I said, I think many came from the factory put together wrong. Apparently nobody (designers or engineers) told the assembly line guys it had to be installed a certain way, so they just threw them together any which way.
    TwoManyXS1Bs and gggGary like this.
  5. thuban
    Ok, 5Twins, that about makes a consensus. I'll wait until I get the shoes and a day you can't ride and pull it down. I have 2K on these shoes. I'd rather have new ones on hand before I pull it down.
    gggGary and Machine like this.
  6. GLJ
    You might want to look into that. The rear brake is all mechanical linkage. What is flexing to give you the springy feeling?
    My XS2 is rear brake challenged. The section of the frame where the brake shaft pivots is not round anymore and the exhaust limits the travel of the pedal to a inch and a half. It works well enough. I think I have Mikes shoes in it.
    In a panic stop I think/hope I would revert back to my racing dirt bike days and use the shifter if I needed more rear brakes. Dirt bikes in the early 70s were drum front and back. After a water crossing you had no brakes for a mile or so and only if you made them drag a bit to dry them out.
  7. TwoManyXS1Bs
    Here's a simple test.
    Bike on centerstand, stoop down alongside the bike's right side, watch the rear wheel while pressing down on the brake pedal.
    If you see the rear wheel rotate backwards a bit with each press of the brake pedal:
    That means that the bottom (trailing) shoe is contacting first, at the cam, pulling down on the hub's drum.
    If you see the rear wheel rotate forwards a bit with each press of the brake pedal:
    That means that the top (leading) shoe is contacting first, at the cam, pulling up on the hub's drum.
    When that rear wheel rotation test stops rotating the wheel, then both shoes are making simultaneous initial contact, indicating that they're finally bedded-in...
    GLJ, thuban and gggGary like this.
  8. thuban
    Thanks 2M. I'll try that but not today. It's a frog strangler!
Share This Page
