Yamaha77
Banned
So today I took the rear tail light assembly apart, reason being, the "running lights," that is, the rear light which stays on and gets brighter when you brake, went out last night when I went for midnight ride.
Very early this morning I got the Sylvania replacement 1157 bulb. Popped it in, turned the key to the on position (NOT the acc position) and the light wouldnt come on. Pulled the brake lever, the brake light came on. Then turned the key to the acc position and the running lights stayed on.
I decided to put the headlight switch in the ON position and viola, the rear light came on fine. It will ONLY stay on when the headlight is on. I dont think this is normal. Do you?
