rear wheel spacers
koyuga
Australia
I have a new spoke rear wheel to fit my 80 Special. I have the brake plate.
I was informed that to change my rear mag wheel to a spoke rim, all the spacers I need are in the mag wheel.
Is that right. I see some of the collars are different.
The internal bearing spacers and the external spacer on the sprocket side are the same. The external spacer on the brake side will be different. The caliper mount acts as the spacer on the disc mag wheel. The drum wheel just uses a tube type spacer .....
full
This is the TX750 version, a little different looking but the same width .....
full
5T is right about disk rear mags, but if you have a DRUM rear mag all the spacers are the same. Well there's a few early, 70-73 spacer differences
