One more thing The year of the engine is not what you need to worry about. You need to figure out what year the stator is. The way the brushes are wired on the stator determines if it is a 70-79 or an 80 up.
These pics are first the 70-79 notice how the wires at the brushes are. Both hook to the left side screws and one is green and one black. The black one hooks under a screw that holds a long strap that goes under the wire screw plus it goes over under the one next to it then comes up over the brush to a screw below the brushes. Marked 1, 2 and 4 in the pic. The green wire is under 3.
The second is the 80 up. Notice the difference in the way the wires are. The green is still under 3. but there is no black wire, The brown wire goes over to screw 2, notice there is no long strap under screws 1 and 2.
The early send power from the reg to the green wire brush and the black wire is ground.
The later power goes to the brown wire, the green wire to the reg where it gets grounded by the reg.
Look your parts over well to determine which you have.
