Remove Top End Without Removing Engine?
Jim
XS650.com Supporter
Kansas City Mo.
I found this tip in the Yamaha Racing Tips Manual. You slot the top end studs so you can remove the top end with the engine still in the frame. Anyone here ever try this?
No but I saw a photo of an Australian XS race bike with the top end off and noted that the studs were slotted.
Cant remember if it was in the frame still or not. Have a look around the XS 650 club of Australia website.
I heard tell the studs were a very tight fit in the crankcase. Not sure if you could turn them out with a screwdriver, straight off. Velocette used the same approach on their singles. Worth thinking about.
I agree Rasputin the studs are very tight in the cases. They would need to be removed slotted and reinstalled for this to work.
I think small flats milled on opposite sides of the stud top to suit a 10 or 8mm spanner would be better. There is enough thread going into the head nuts for this.
Removal of factory installed studs tends to be difficult not because they're installed under heavy torque but because of the locking compound Yamaha used. A race motor typically gets very frequent teardowns. For street/highway use, I don't know if you'd want to trust studs installed in a way that would make the slots useful.
I've got that same article for Yamaha XS650750 race bikes. I would bet that the engine is out and apart when the studs are notched.
They also probably used Champion, Trackmaster and C&J frames where there is lots more room on between engine and frame. I might scan these pages and post it sometime. Has lots of racing tips including porting the head.
Agreed.
On my 80 frame, there's plenty of clearance for the inner studs. The rocker box clearing the frame is another question. Just as a guess, the gap 'tween the box and frame looks to be about the same as the alignment bushings. Of course if one was to do this.... trimming a tad off the bushings would work.
talking about this to people i had an argument put to me being against doing this, due to not having the studs locked in, (as per Factory), getting the head torqued could be problematic, studs could turn in the case, and has the potential to strip the threads in the bottom case......or uneven torque
Eccentric locking stud remover tool like 4g has, and I don't see why you'd need either slots or flats to get them out. Protect the threads if needed. Agreed, could be a bear to get them out the first time, w/ engine out of frame, ..but with that same tool, maybe not...
I've been putting off doing my top end, mostly because of having to pull the motor again (no space to work, no time, no....) anyway this is intriguing. found these stud pullers,
There might be some confusion here; this thread is dealing with studs that have already been freed from the crankcase and the adhesive removed.
In my fairly experienced opinion; you will NOT remove the studs from a stock motor with the head and cylinder still on the engine. To remove you have to heat the studs where they go into the crankcase. We ain't talking a match, play a propane torch over the stud pretty good. Some long socket extensions to get the extractor down near the base of the stud really helps.
I was also thinking of this, wondering how much torque you could apply to a tool like the one shown above and would the stud break free of the case or would the tool damage the threads. Hmmmm…. it's been more than once where a shortcut has cost more time and money.
+1 ............Red highlight is the bases of this thread............Not to be confused with.............. "oh ok i can do this to make my cam chain guide removal easier the first time, so i don't have to remove my motor"
