1. Dismiss Notice
    Dismiss Notice
Replacing clutch question
Discussion in 'The Garage' started by Jirish650, Jun 12, 2020.
  1. Jirish650
    Jirish650 "We cant stop here, this is bat country"
    9
    2
    3
    Oregon
    Got into the clutch on my 1980 xs and found two, what looks like possibly some sort of snap rings. This is the first time I've got into the clutch side of this motor and it was apparent previous owner had got into it before but the bike ran fine except for the clutch slipping a bit and the kick starter spindle was not correctly engaged thus why I took it apart. Has anyone else come across this? They were just laying at the bottom of the case, and I have never seen anything like them, wondering if they got accidentally dropped in on last time it was disassembled.
  2. 5twins
    19,885
    11,641
    813
    There's a light weight coil spring on the starter gear assembly that helps throw it out of engagement, #2 in the drawing below. Maybe those are parts of it that have broken off .....
    [​IMG]
  3. Team Junk
    Team Junk XS650 Junkie XS650.com Supporter Top Contributor
    I'm thinking door #3
    TwoManyXS1Bs likes this.
  4. Jirish650
    9
    2
    3
    Oregon
    Hi 5twins, its definitely not from the Kickstarter spindle assembly, everything working properly and the rings are really really thin.Hard to think someone dropped them in and left them without noticing but I have come across strange things before that people did to their motorcycles or cars. I couldn't find or think of any other application that they would belong to so hopefully was just a weird mishap that they were in there.
  5. TwoManyXS1Bs
    The hooked ends, looks like a broken retainer ring clip that fits at the back of the 80-83 clutch hubs...
    GLJ, timbeck and Team Junk like this.
  6. Jirish650
    9
    2
    3
    Oregon
    You are referring to the retainer wire for the clutch plate? These rings are only about 2", clutch retainer wire much larger and as stated everything is in working order far as I can see.The kick starter spindle spring and tang were not positioned right which is another reason I decided to look into that side of the case but all parts are there, nothing is missing. Thought the possibility that there was a special model/year these may have been used but cant find anything they would be applied to, previous owner dropped them in there I suppose, pretty weird.
  7. 5twins
    19,885
    11,641
    813
    That return spring I mentioned in post #2 is the only thin wire large coil spring I know of under that cover. Did you pull the starter gear assembly out and check yours? It's behind the bigger gear in the red circle .....
    [​IMG]
  8. Jirish650
    9
    2
    3
    Oregon
    5 twins I did inspect mine, everything looked good and I did replace the original starter with new one before installing the engine back in the frame.
  9. TwoManyXS1Bs
    We *have* had members finding things in their engines that were simply overlooked leftovers from previous work...
    GLJ likes this.
Share This Page
