I come from Pirate4x4...
http://www.pirate4x4.com/forum/shop-tools/434877-harbor-freight-good-tool-list.html
Bought some knob assemblys for the metal side covers. The hole for the roll pin was going the wrong direction so the knob ended up being vertical instead of horizontal when locked down. A small thing but annoying.....they sent me some replacements right away.
Update: They sent the same wrong parts again. Add another item to the don't buy from Mike's list.
These are the ones I found to have problems:
Screws for "points" ignition.................thread was too short
Throttle shaft screws..................wrong thread
Carb intake manifold barbs..................rubber cap splits within a year
Carb intake manifolds........................very poor fit, do not seal well causing high idle and chirping
ATU bob weights spring..................tension is not correct as compared to OEM
The fitting for the bottom of the oil pipe can be bad, I'm guessing poor quality control. This one my buddy got couldn't even be used the threads were so poor .....
Petcock screw washers...
MikesXs on the left, OEM (boats.net) on the right.
The Mikes broke as I was threading them on the screw and leaked like a sieve. Junk.
OEM worked perfect... of course
