I have a knocking from the right side clutch cover. I made sure valves and cam chain were adjusted. Is this a rod knock? Having trouble uploading the video. Running 15w oil right now. What could it be? Thanks
It’s hard to tell from the video maybe pull off the Side filter cover and see if the bolt holding the filter is loose. Then if that’s not it drain the oil and see what’s going on inside the cover. Not sure of any other way to check the rods other than tearing down the engine. You can do the old mechanics trick of placing your ear on the Handle end of a screwdriver and placing it around to find the spot of the sound.
