1. Dismiss Notice
    Dismiss Notice
Featured RobinC
Discussion in 'The Garage' started by MaxPete, Nov 3, 2018.
  1. MaxPete
    MaxPete Lucille, Betty, Demi & Gretel: I ask, THEY decide. XS650.com Supporter Top Contributor
    Thanks Superjet - much appreciated!
    Pete
    gggGary, Meddy and Jim like this.
  2. Wulfbyte
    Wulfbyte XS650 Addict
    I thinks it’s awsome the way you guys help anyone and everyone in need! You guys rock! I look forward to reading something on this site everyday! My spirits are always lifted!
  3. Jim
    Ironic isn't it? This forum is literally the epitome of what social media should be.... mostly populated by old guys that are technically challenged....
  4. Yep, that's me. :confused: Nice pic Jim.
    Mailman, Jim and gggGary like this.
  5. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    Might be best to cut out the section of frame, so that Pete can cut off the brackets, but before he does that he will be able to take measurements and get the positioning exactly right before cutting off the bracket/tabs.............The angle and position is pretty crucial i would say.......
    nj1639, Mailman, Skip and 3 others like this.
  6. CBJamie
    CBJamie BIKE ADDICT
    Pete, I have the spring also, I will get this cut off this weekend and get it sent out early next week. No need for thanks, glad to give back to the people who make this forum such a great place to be. Robin was one of those people, and if giving a small part will help his son keep Robin's beloved XS in the family and on the road I'm more than glad to help.
    TwoManyXS1Bs, Mailman, Jim and 6 others like this.
  7. MaxPete
    Thanks again Jamie - you’re one of the good guys.
    Pete
    TwoManyXS1Bs, Mailman, Jim and 2 others like this.
  8. 5twins
    20,405
    12,628
    813
    '77 and later stands are all the same. The '82 and '83 stands are essentially the same with a couple added tabs for the side stand switch, as mentioned. Here's the one I pulled off my '83 (on the left) and the earlier "no tabs" version I replaced it with .....
    [​IMG]
    You'll need the associated mounting parts as well, in particular the spring post bracket. Most are still available from Yamaha .....
    [​IMG]
    https://www.partzilla.com/catalog/y...0d/stand-footrest-brake-pedal-xs650d-e-e00650
  9. MaxPete
    Thanks 5Twins - much appreciated.
    CBJamie is sending me his hardware and I'm sure it will work - but your photo will sure be helpful too!
    Pete
  10. 5twins
    20,405
    12,628
    813
    A couple more little things - the parts diagram I linked to has the spring post bracket drawn incorrectly. It shows the post on the bottom, below the pivot. It should be above the pivot as shown in my drawing above. Also, the "loose" end of the spring goes up. Not sure if that matters or not, but that's how all the drawings show it and that's how I've always installed them. It may provide more clearance for the mounting bolt head that way.
    [​IMG]
    In this pic, the special lock tab is missing but it shows the other parts more clearly. The flat washer needs to be a fender washer .....
    [​IMG]
    [​IMG]
    gggGary and MaxPete like this.
  11. Superjet
    Superjet XS650 Guru Top Contributor
    Reminds me I got to cut off part of the switch mount of the spring tab since I am not using a switch. Will make it easier to get to that sump plate bolt down on that side. Glad all worked out for Robin's family. Thanks Pete! J-C
    MaxPete likes this.
  12. CBJamie
    CBJamie BIKE ADDICT
    This is from a 76 standard. Will this work?
    MaxPete, GLJ and Jim like this.
  13. 5twins
    20,405
    12,628
    813
    The '76 stand was a one year only part. '77-on stands are a dime a dozen by comparison. It might be better to pass that stand along to some needy '76 owner.
    GLJ likes this.
  14. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
  15. 650Skull
    One advantage for using that bracket instead of the later ones is if a sump extension was ever considered in the future...........cant be used with the 77 and later stands. Not enough room without removing the side stand all together...........Note, 5twins second pic in post #70
    gggGary likes this.
  16. gggGary
    IIRC the 76 exhaust is the same as the 77-79 so the stand should work?
    650Skull likes this.
  17. 650Skull
    An extra brace on the tang would come in handy
  18. MaxPete
    I’m virtually certain the Robin’s son won’t be experimenting with sump extensions and yes, the ‘76 and later ‘77 and ‘78 exhausts are identical (Robin and I compared his ‘77D and my ‘76C) - so yup, I think that stand will do fine Jamie.
    Pete
    CBJamie and gggGary like this.
  19. CBJamie
    CBJamie BIKE ADDICT
    Ok, I'll get this shipped out Monday or Tuesday.
Share This Page
