Rolling XS650 Engine Stand
The TC bro's one won't give very good access to the bottom of the motor if bolted to a panel with wheels (i.e. a dolly). I know this because i did that. You would need some spacers, but going too high could be a bit unstable.
Wood us easy but its also not udeal for something like this. Ive heard those tc stands are flimsy hot garbage so ill keep looking ideally id like something with a bit of clearance underneath as well. I may just have to bolt some stuff up together. In the end id like a stand that i could fire up the motor on as well.
Hi Adrenaline-Junky,
try using Dexion, HandiAngle or any brand of slotted angle.
It's like heavy duty Meccano.
That stuff and a fistful of nuts and bolts will build you just about anything.
