xs650newb
Hey everyone,
Just want some confirmation.
Went out for a ride, bike all of a sudden dies. Get back to my place and the battery is completely dead. I know before I left the charging system works because I checked it one or two days prior.
I charge the battery and check the current draw with the key ON and engine OFF. It is well over 10 amps so I immediately turn key off. I start by looking in my headlight buck for a shorted wire but don't see anything. Check current draw again with key ON and it is back to normal (2 amps with headlight off).
Go for a ride and SAME thing happens again. This time I check the charging system.
Results:
Resistance between three white cloth wires coming from alternator: ~0.7 ohms.
Resistance between the two slip rings: 1 ohm.
So the slip ring resistance is bad. I guess the rotor went bad? Can it go bad all at once? I mean, everything was great the day before. Also, the problem seemed to have fixed itself for about an hour or two between testings. Can something else be wrong? Maybe a frayed or pinched wire somewhere?
Best,
Adam
Results:
Best,
Adam
