1. Dismiss Notice
    Dismiss Notice
Rotor Winding Tooling
Discussion in 'The Garage' started by Jim, Jul 22, 2018.
  1. jetmechmarty
    jetmechmarty What should I put here? XS650.com Supporter Top Contributor
    I acquired a rotor many years ago from a friend on the Micapeak email list. It was well under 5 ohms. 18 years on it, so far.
    Jim and gggGary like this.
  2. Jim
    Making the winding form was straightforward. All I had to do was make a new inner piece. The rest of it worked just fine.
    Cranked out 500 turns.
    Wrapped in fiberglass tape just like the XS coils (didn't get a pic) and pressed it back together.
    It's not splined like the XS rotors, so I made a punch mark when I took it apart. Wound up nailing the alignment, so balance should be pretty close.
    Was shootin' for 3.8 to 4Ω... nailed it:D
    I'll let the JB Weld harden overnight and finish putting it together. The taper on the hole turns out to be identical to the XS taper, so balance and runout tooling will work for this rotor.
  3. Superjet
    Superjet XS650 Guru Top Contributor
    I like the punch marks for alignment. Sometimes its the simple things similar to this that help greatly!
    Paul Sutton, Mailman, 59Tebo and 2 others like this.
  4. mrtwowheel
    mrtwowheel Honda Etched On Brain Top Contributor
    Which CB750 is this for? The DOHC 750 from '79 up, or the SOHC CB750 built up till '78?
    The DOHC 750 and 900 have a big following now, they'll always be looking for rotors.
  5. Jim
    I believe it's for the DOHC750 Scott.
    mrtwowheel and Paul Sutton like this.
  6. 59Tebo
    59Tebo 59Tebo Top Contributor
    Hey, Jim, you've got quite the cottage industry in the works there. A "side job" that could pay for all your other projects (and keep you off the streets at night! :wink2: ). Catalog all you winding forms and tooling, keep detailed notes (i'm guessing you already have), and you'll have built the "better mouse trap" the world beats a path to your door for.... :twocents:
  7. Mailman
    You sure do nice work Jim! :thumbsup:
    59Tebo, gggGary and Jim like this.
  8. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    Sweet Jim!
    Those DOHC STATORS were fragile, bump the RH crank cover and plan on a new stator.
    Paul Sutton, Jim, Mailman and 2 others like this.
  9. Grumpy32
    Grumpy32 XS650 Member
    Jim is correct Scott, that rotor is for the DOHC Honda 4's. It was used on the cb750's, 900's, and 1000's, yrs 1979-83.
  10. Jim
    Slip ring looked pretty rough to start with...
    Much better now. All back together. As with the XS rotors, there's a slight increase in resistance when it's assembled. I'm guessin' there's a bit of inductive reactance going on when the iron core is pressed together. Still... 4.1 Ω is pretty close to what the guy's on the CB site said was preferred. According to them, the book calls for 4.5 Ω, but their years of experience has showed them that 3.8 to 4 Ω makes for a better charging system. 4.1 will do.
    Runout is good, but I can't check the balance because my balance shaft is too light for this much heavier rotor. I'm currently epoxying extra weight to it.
    Please stand by...:er:
  11. Grumpy32
    Excellent!:) I'm standing by...
    Paul Sutton and Jim like this.
  12. Jim
    Thought something was odd. Went back and looked at the pics. Yesterday was 3.9 Ω and 4.1 Ω today... but in both cases, the coil was already in the rotor. Hmmm.... different temps maybe? Just rechecked it...
    Guess we'll call it 3.9 to 4.1... depending on how I hold my tongue. :umm:
    TwoManyXS1Bs, Mailman and gggGary like this.
  13. gggGary
    All my meters drift down slowly for about 3-4 seconds before they settle when ohming rotors.
    "Temperature Coefficient of Copper. The Temperature Coefficient of Copper (near room temperature) is +0.393 percent per degree C. This means if the temperature increases 1°C, the resistance will increase 0.393%. ... The wire resistance will go up 0.00255 ohms (10 degrees * 0.00393 per degree * 0.0649 ohms = 0.00255 ohms)."
    YamadudeXS650C and Jim like this.
  14. gggGary
    59Tebo and Jim like this.
  15. Jim
    Yeah, mine too. All my readings are after 20-30 seconds.
    Mailman, 59Tebo and gggGary like this.
  16. Machine
    Machine Race the wind Top Contributor
    A fresh Jims rewind rotor , ready to spin forever !
    -R
  17. Jim
    Honda CB750 rotor balanced, clear coated and ready to ship. :D
  18. Jim
    I've had this iron since my Air Force days... and I retired in 94. I guess we can say this tip gave it's all.
  19. ReycleBill
    ReycleBill Part Time Tyrannicide XS650.com Supporter
    Is it easier to count turns or simply use up a measured length of wire? The end result will be the same.
    Jim likes this.
Share This Page
