Rotor Winding Tooling
OK, the last of the stuff I ordered finally showed up this afternoon. Nothin' else for it.... time to turn out a coil.....
402 turns of 22 ga. wire. Had to stay under 3.03" OD. Came out at 2.92". Yamaha calls for 5.25 ohms +/- 10%. So... 4.725 to 5.775 ohms. I hit exactly 4.8 ohms. I'll take it :)
I think on the next one I'll try to push 420-430 turns. Now I gotta let the red varnish cure for 12-16 hrs.
I'm gonna buy the wife a new toaster oven so's I can drag the old one out here in the garage.....:rolleyes: Then I can cure it in 1 hr. at 185F
Well that’s really interesting. That’s really all there is inside a rotor? I always thought it was some crazy complex pattern, like an armature winding. That’s pretty cool!
One end of the coil, from the innermost winding, has to emerge from the inner, and is in contact with each layer. Given that many failed rotors show 0 ohms, I wonder if that's a risk zone, possible abrasion creating dead short. Would it be worth it to have a thin dielectric film, or spaghetti tube, to isolate/protect that emerging wire?
Putting it all together.
Removed the coil from it's winding form. The varnish was still a little tacky in places. Started wrapping with fiberglass tape....
That's been a concern to me also Steve. What I did was separate the wire and run a double wrap of tape around the coil, laid the wire radially across the coil and ran another double wrap around it. Should be well protected from abrasion...
Here's a shot of the test fit........
Coated the coil in epoxy and pressed it all back together...
Reinstalled the slip ring and soldered the wires back on.....
.... and coated the solder and screws with the insulating varnish.
After it's all cured up, I can finally get the left side of my engine back together.:)
Too funny how simple it really is for something to cause headache for so many. You would think that the aftermarket would do a little more R&D to ensure the rotor would be at or over what stock is......wait a minute, that would be a stupid amount of money to do. Nevermind, lets see what the backyard guys can do first then copy and bring to market lol fingers crossed Jimd for your prototype to perform and last!!! Great details and write up!
Jim I would just like to say how much I enjoy these technical articles written by you and some of the other more knowledgeable members. I frankly never gave much thought to the construction and design of these components, but it has made me think and do some research to be able to better understand it. You also take excellent photos and write in a clear and concise manner. Good stuff!
Thanks Bob. :)
You're on the list Pete.
Scott, yeah.... I'm gonna move forward with this. Mine will be a test bed and there's an 80SG out in Az. that's gettin one for testing. I have 4 more "cores" I'll put out there for testing when I get 'em rewound. But right now, Fall is fast approaching and I want my resto on the road before the snow flies. So the next few weeks will be back on that.
If you were to let some of your epoxy fully cure, and then applied some more epoxy to the cured epoxy...…….would the uncured epoxy reactivate the cured epoxy? Would they separate at the glue line, or not?
Scott
Once an epoxy 'cooks off', it won't reactivate. It's a one time chemical reaction. The only way to bond fresh epoxy to 'cured' epoxy is to roughen the surface. That gets you to about 60-80% of original strength.
Glue line separation at the centrifugal forces we're talkin' is a distinct possibility.
When these 3 are reassembled, is the alignment of the keyway with the timing mark assured, or do you have to keep your wits about you?
Sorry Steve, forgot to respond to this...... I put punch marks on the three parts before I pressed it apart. A simple matter of lining up the dots.
