.... The rotor above failed the runout test... to the tune of .015-.020" at the outer ring.
It is. Just for s&g's I checked the rotor with and without the ring plate. Same reading. It's 15 to 20 thou.... you can literally see it with the MK.I eyeball... no TIR gauge needed. It's that bad.Is the phenolic plate of uniform thickness?
I'm sure it would. I didn't take a pic but before I put the JB Weld on it, I put a straight edge across it. It's definitely bent.I wonder if it would show similar runout if position measurements were taken from each of the 4 prong endfaces?
- Parallel plane, the upper press plate is parallel with the bottom press plate.Curious about your reassembly press fixturing/procedure.
Thinkin' out loud here.
There's 3 types of alignment during press-assembly.
- Self-aligning, let the top align with the bottom's shaft body.
- CoAxial, the upper press plate is perpendicular to the tapered shaft axis.
Ooooh... good point. You have any idea what the typical clearance is 'tween the rotor and stator?Edit: Just thought of one.
The rotor OD may need to be shaved if the runout affects it...
Yeah there is. Might just use it for parts.were there any usable parts on that rotor that could be matched with other rotor parts?
I don't have calipers with deep enough jaws, so I set a rotor inside a stator and could not get a piece of .032" safety wire between 'em. So I stuffed a tooth pick 'tween em and measured the crush. Gap is .028". So.... 14 thou. wobble would rub. That ain't much folks.Off the cuff, On assembly if the stator slot isn't aligned with the crank location pin the stator is cocked enough to make the rotor rub (HARD)
