XS650D
XS650 Junkie
I have the bike running really good I feel.My only issue which may be normal is when in top gear cruising along at approx 4000 rpm with throttle barely cracked I get a very slight hesitation were it feels slightly jerky.
Is that a sign of rich or lean and if so what carb circuit should I be looking at ie: fuel/air screws, pilot jets or needle clip position.It will not do this while putting around the parking lot in 2nd gear with throttle barely cracked and will pull smoothly without hesitation or stumbling with approx 1/2 throttle roll-on.Full throttle is perfect. Could this be right were the Diaphragm just starts to lift ?
