Shift cup/actuator installation question
Muckroot
El Paso county, Colorado
Hello all,
Bit of a newbie question but My manual is ambiguous about the correct installation of the shift actuator thingamy under the left case cover. have I installed it correctly? or does the metal side go into the cover with the plastic presenting outward?
You got it so far ! Practice the orientation of the spiral teeth in the worm actuator. Don't loose the ball bearing that pushes on the rod.
Search" clutch actuator " threads..
When you re install your actuator arm, be aware that it can be inserted in a couple of different positions. You want the arm to be at roughly a 90 degree angle from the hole the cable enters the case. That will provide the best mechanical advantage.
