PLUM CRAZY
XS650 New Member
This is my first XS650 and first motorcycle I have attempted to fix. I am replacing the shift shaft and have reached a roadblock. I have both side covers off, and the clutch disassembled. The repair manual says to remove the circlip and washer on the shaft. After that, the shaft should pull out, but I can't locate the clip and washer. I've read on the forum that both are on the left side of the engine. I see a bolt attached to some sort of protective flange covering the shaft. Do I need to remove that? Could you help me with whatever I'm missing to replace the shift shaft assembly? much thanks
