rshane53
ramjet
Hey all, I haven't posted in a while. I have my 71 apart for some maintenance and have a few questions. I have been experiencing difficulty shifting into 1st gear when downshifting after the engine is hot. When the bike is cold it shifts no problem. I have removed the clutch and after inspection it appears to be in great shape. When I removed the clutch plates so that I could spin the clutch boss with my hand I found that in 1st gear there is a lot of backlash. With the transmission is 1st gear there is about 50-60 degrees of rotation of the main transmission shaft before the rear wheel begins to turn. As I shift up through the gears, the backlash becomes markedly less. In 3rd, 4th and 5th there is very little backlash. Could the excess backlash in 1st gear be causing the difficult shifting when the engine is hot, and does anyone know how much backlash is normal?
