Shop Lighting Tip
Ah yes, I'd forgotten about the metric shit-ton. Thanks for reminding me.
I need a set of those measuring spoons for SWMBO.
Hey downeasta' I think you missed one:
a boot load
Don't know where it would fit in the order though ;-)
Glenn from Wiscasset
BTW, I switched my three 8' long, two bulb T12 units to Hypericon no ballast LED type two years ago and they're fantastic. Instant on regardless of how cold it is in the garage!
I've had 1 LED over the main workbench for several years. this thread inspired me to bite the bullet and replace my other 4, 4 ft twin tube fluoro's with 5000 lumen 4 ft leds. Farm and Fleet has them on sale for $25. Plenty of light for these old eyes in my 14x22 garage.
I'm enjoying this thread and its related testimonials, but there's one thing I haven't heard a peep about (or if it was discussed I missed it): Color.
What color are these LED strips putting out? Are they garish white, warm yellowish, nasty greenish, blueish... what's everyone's take on the color of light they emit?
I want light that is between white and yellow, but nicely bright. I get that everyone has the "bright" covered, but the quality of light is huge to me. The last thing I want is tired eyes because of my shop lighting. Some "blues" tend to almost vibrate when you look at them (some headlights come to mind).
Thanks guys--rock on.
I'm not familiar enough with color temperatures and such to give a scientifically meaningful response but I will say the LED's I'm using are very white. As far as I can tell with my worn out old eyes, there's virtually none of the yellow tint common with incandescent bulbs.
They're even somewhat whiter than my modern electronic ballast fluorescents and decidedly brighter and NO flicker which I always found annoying with fluorescent lighting.
I've been going with 6700K which is as about as white as you can get without going blue. The 6700 LEDs are definitely brighter than my old 6700K T8s. Since they are on clearance at Lowes I went and bought them out so I can convert the rest of my lights over.
That's a good point. My workshop is currently lit with a 50/50 mix of daylight white and warm white fluoros, because that's the way I like it.
When it comes to LEDs, I don't want a glaring white garishness about the place.
Yes color matters in home use, I replaced the incandescent ceiling lights in the van with LEDs and they are OK but too "blueish" for a comfortable homey feeling. All the A60 LED replacements I've been buying for the house have a decent 5000k ish? color. Changing 60 watt bulbs to LED is a no brainer now. I think the power companies are subsidizing the bulbs at the local stores, 4 for about $7.00
What are you doing in that shagin wagon that you need a "homey" feelin:devil::bed:?
There's color temperature, measured in Kelvin, and also CRI, measured on a 100pnt scale. Both are important in finding the right light source for the given job.
Color temp refers to the color of the light itself. Shining on a white surface or looking at a headlight as it comes down the road, what color "white" it is. This is the "white balance" adjustment on your camera.
Colors are exaggerated:
CRI, color rendering index, refers to how well colors show up when lit by a given source. This is particularly important for some tasks such as reading spark plugs, sussing a 40yr old wire harness, or knowing when to pull the t-bone off the grill.
When talking light we're talking additive color mixing. White light being the mix of all colors in the visible spectrum. Incandescents and other sorts of natural light sources produce light smoothly across the spectrum. Most LEDs produce only certain slices.
The missing chunks may not be visible to the eye when looking at the light itself, but they do become visible when reflected off objects. Missing the full spectrum, the objects' color seems 'off' or muted.
When choosing an LED fixture, ask the following questions:
How bright? Lumens
How homey, cozy, natural, focused, awake, do I want to feel? Color Temp
How important is it that colors look true? CRI
The X factor is that all three of these numbers are somewhat subjective and can be an inaccurate judge between manufacturers or even product lines.
Now, in my line of work, we add in the want of smooth dimming to 0%. Most LEDs, even those labeled ''Dimmable", do not. But the good ones keep getting better. Some of the best will 'amber shift' their color temp when dimmed, just like an incandescent. Sexy. But here we're talking $1500 for a single 1000w equivalent theatrical spotlight.
A really good commercial task light, a T8 replacement, can be easily north of $150 per 4' fixture. This would have options of brightnesses and color temps, all with a CRI 87-92. That's pretty damn good.
Cool, er um warm! Back in the day we tripled a merchants sales by changing his display lighting from fluorescent to quartz bulbs. We practically had to beat him with a stick to make the change.
Fluorescents are nasty things. Flicker, low CRI, noise. Known to cause headache and nausea.
Our eyes and brain evolved in incandescent light. The closer we can hew to mimicking the sun (high CRI) and its perceived cycles (careful choice of color temp), the happier we are as sensory beings.
Sales 101: get your customer happy and comfortable. Quartz, an incandescent. No wonder sales increased.
So, I'm standing in the WalMart checkout line, surrounded by shelves of various "impulse buy" items, and see this:
Ok, I'll bite.
There's a dark zone hallway in my home that could use this.
Amazing, it lights my way when entering, turns off after I've passed.
Plan to get some more now...
