For Sale - Spare parts
member3480
RICH
NEW JERSEY
Tubes and legs
Will sell just one
$35. Each or both for $50 plus shipping
7/8” handlebar custom switches
Three button switch. (New)
$39. Each or both for $70. Free shipping in USA
Masters left and right. ( New)
$40. Each or both for $70.
What's the piston diameters of the Master Cylinders?
If you are talking about the plunger that goes in and out it 10mm without measuring the rubber around it but I think most of them are the same. I was curious and measured the other two I have and they are different brands and they too are 10mm.
Can I ask why the size makes a difference when the bore hole could be 8mm 10mm 12mm and the plunger will match that?
It's all about how much fluid is moved and the pressure it builds.
interesting . Have to play with a couple to see how much the difference is. Never had a problem with any I used in the past. Are you trying to match up with a certain slave cylinder for easy pull. Plus have you found one that works better on a XS650 with a slave cylinder. I have used Harley masters on suicide clutch with a KTM slave with no problem. Have to make one up for a bike I have here so that's why I am asking. Never did one with handlebar master on a XS650 so should be fun to try.
I've been contemplating replacing the 14mm sloped front brake m/c on the SG for a level one and a 16mm for the KZ hybrid.
