Found some additional parts on craigs list. And I picked them up today as well. All the surface rust is coming off. Went to check plugs and one came out with a helicoil attached. Got new heicoils and had a hard time starting new one. I ruined a new plug and helicoil . Now I have to get a tap,helical and new plug . I was careful and used oil on the plug (inside) but I failed anyway. The plug hole is fine I just have to chase the threads and carefully insert new coil.
I removed aftermarket seat,road pegs and rack. I'm going to make it as stock as I can. Oil looks fresh. My guess is previous owner had plug come out with helicoil and figured it was hopeless. I'm really happy with the bikes condition. I have all original parts now.
Question... the lower fork chrome is peeling and poor. What are my options ?
As soon as I get a battery I'm going to see if yeller will run. Tank is clean and after plug issue is
resolved I'll try to start it . I also want to check compression.
I'm doing the easy stuff , but I'm still thirst for more.
Regards,
CPKID
Slot to do , but
Regards,
CPKID
Slot to do , but
