Starter Gear Fix!
It's strange when looking on Partzialla website for these new parts(they don't have any but I use the site to get the OEM numbers ) I checked the parts numbers from 1975 to 1978 and the only parts number that changed is for the number 4 gear not the clip or the return spring
Think it's cause it was a SB, replacement springs for all years are of the heavier pattern. Wouldn't get too worried about the spring once fixed. If you get the engine fettled so it starts without excessive cranking the starter tends to work fine. I've had several with a starter that was kicking out when they first got here but after a wake up drill on ignition and carbs It was no longer an issue. Perhaps over advanced timing contributes to starter issues.
From what I have read on here, the one from Mike's is just as good. I cannot remember who did a comparison but it was near the same tension after tweaking it in a vise.
I did a comparison on an assortment of starter hair clips and as long as the “fish scale pull force” is over about 6 lb - it will be fine. If the engine starts easily, so much the better. Lucille starts so easily now that I can barely hear the engine crank before it starts to run.
Here is the thread - the starter gear saga starts at post 257:
http://www.xs650.com/forums/the-garage.2/
I still have the original clip which I believe was stock
I'm going to compare the 2 the new one is probably thicker I just didn't have the tension high enough for it to keep working properly and I will get it running as good as possible to help the starter not work as hard too
Good advice from ALL of you guys and Thanks a Lot for being patient with me
Hi Pete, Do you still have points in your bike?
Nope - On Lucille (1976 XS650C) I swapped over to a PAMCO Pete system with an e-advancer quite some time ago - and it works great! The point of pain was finding a secure out of the way spot for the little blue box. I still have the stock airboxes on Lucille and there aren't actually that many places for it in there under the seat.
My cafe donor bike is an '81 Special and while it does run, I haven't ridden it more than a few km so I am not sure how good it is just yet. My current plan, if the CDI isn't solid, is to switch to one of the slick new PAMCOs which has the advancer function built right onto the circuit board.
Pete
ok I found the correct thread after somehow posting in the wrong one. I've "tightened" the spring clip and it seems to be engaging with the starter now but I'm wondering if this gear is returning to the correct position. What do you think?
Its not resting flat against the outer gear. Im wondering if the coil spring isnt strong enough or when it starts to rotate it will be thrown out?
It can't stay engaged because when the engine starts the starter stops spinning. This lets the return spring push the gear out of engagement. The engine spinning the gear faster screws the gear back on the splines as well.
Say it did stay engaged while running(as my bike is now doing) would that just be a bad return spring or would it be the gear being stuck on the shaft in some way?
Just went through this repair on my 650B this week. Got the gear from Mikes. When I took the old gear out the teeth were in real good shape but the spring had less than 2lbs of drag. New gear had a thicker spring and over 10 lbs of drag. Before I put the new gear in I used my dremel to give the leading edge of the teeth a little angle to maybe let the gear engage a little deeper into the crank gear. So far so good. Everything is working as it should. Bike has 30,000 miles on it and this is the 4th gear I have put in it. Bought the bike New in 1975.
mjpchief, didn't you find a lot of metal in the cases on oil change from use of the starter or did you just not try and use it when it started slipping?
Personally, I prefer original parts. The MikesXS stuff is knock-offs. If you look at the beginning of this thread, you'll see the MikesXS clip is ground flat on the sides so it's not as thick as an original. I've got to think that makes it weaker. Sure, it may tension up OK after you squeeze it tight, but will it hold that tension for long? Probably not as long as an original. Unfortunately, the original parts aren't available anymore. You'd have to find some on eBay or something, or you could use nice used ones. I think I'd even do that before buying the MikesXS stuff. You would want a '76 or newer gear and clip. Maybe gggGary can help you out with that.
Hey buddy i have a 75 and im getting the grinding upon starting and sometimes stays grinding like 2-3 secs AFTER engine is already started.
Should i just squeeze clip as much as i can to get it tensioned back up or replace the clip and the gear? If replacing is your recommendation can i just get the thicker clip or do know?? I have no idea what I currently have as i havent been in there yet.
Hello! I have a 75 too and getting the grinding noise upon starting. Do we have the thicker clip or still the thin one?? Also what gear do we have? Can we use new clip with our factory gear?? Thanks alot for your insights
The old skinny wire clip won't work for very long. That's why it was updated to a heavier wire clip. And even so, that new heavier wire clip also spreads open and slips over time. Yes, that return spring isn't very strong. PamcoPete even recommended leaving it out several years ago. He said he believed it allowed the starter gear to engage better. So I took mine out, but I see no improvement in the starter engagement. I will most likely put it back in eventually because there is a minor "glitch" with it removed. When you park the bike on the sidestand while it's idling, the missing spring allows the starter gear to drift down into the crank gear and you get some minor, random grinding.
This is whats in my bike now, i have a 75 and this is the part. Is this the updated one because lookin at this there no way to squeeze it any tighter! Its already touching. See pic. Thanks
75xsFLORDIA,
Sometimes squeezing it too much causes problems. I'm not the one to talk to about this problem. I did the spring mod and tried new parts too. I didn't have much luck. I just kick it. There is a lot of info in the "Tech" section. Also if your gona be taking the cover off and on, a Cometic gasket is the only way to go. It's reusable, no sealant and seals solid.
75xsFLORDIA,
Which Cometic gasket are you using there seem to be a lot of different materials
I take it you cut your own
Below I documented the fix for the slipping 4th starter gear. I want to add the original poster/author is below. All I did was test and post pictures to what he is writing about. I applied this fix years ago to a kick starter spring the same way with success.
The reason why the starter slips and spins out because the spring has lost it's tension or was never set properly. This is what I found.
The spring has to be at 6 pounds. I found when it gets to 4 pounds it slips. I tested this on 3 other bikes. They were all at 4 pounds that slipped, new aftermarket-used aftermarket OEM or otherwise. Just takes 2 pounds difference.
This is what happens to the gear when the spring is at 4 pounds pressure.
This is a fish scale I bought at Walmart for $15.00. I'll keep it and use it to adjust the steering head.
Here is the factory spring tension rate
I have gotten two of Mikes stater kits for 2 of my bikes and one worked fine and the other just spun. This is what I've found on the adjustment. You can only squeeze the spring in a vise. No matter how hard you squeeze you only achieve 6 pounds. So if you don't have a scale you will be in spec. Just don't over squeeze on the vise and disform the spring.
Here is what I've also found. On the left is Mikes spring. Notice the flat sides to fit the new gear. To the right is a OEM NOS spring, it's fatter-just not grinded flat. When I put a NOS spring on Mikes gear you only get 4 pounds. If you squeeze the spring you get 8 pounds so that is the best set up. *Note* if you put a OEM spring on a OEM gear you will only get 4 pounds, the spring has to be bent in a vise.
You really can't bend it on the bike and not take it apart this this.
OEM part #
Below is a post from the author with his fix I just documented and tested. This will fix the dreaded starter problem. You could probably just remove the slipping gear and squeeze the spring and you would be fine.
#Electric starter problems on the XS650 are very common, and almost always due
to a non-functioning #4 gear, the one that slides down the bendix helix and
engages the ring gear on the flywheel. Symptoms are a starter that does not
engage, a starter that just grinds ineffectually, or a starter that kicks out if the
engine does not start immediately. The usual remedy is to replace the gear
complete with it’s spring clip, but there is an easy way to fix erratic and non
functioning starters without changing the #4 gear, even if the gear is showing
signs of severe wear.
When people remove the offending gear it is often badly worn, and they
assume that is the reason the starter does not work. But exactly the converse is
true.
IT IS NOT A CASE OF THE STARTER NOT ENGAGING BECAUSE OF A
WORN #4 GEAR. THE #4 GEAR ONLY WEARS BECAUSE THE STARTER IS
NOT ENGAGING.
One will find in removing non-functioning #4 gears from an XS650 that there is
still lots of tooth left. Now the bendix on a car will continue to engage till the
teeth are completely snapped off, and even then will turn the engine jerkily.
One usually changes them to avoid damage to the ring gear on the flywheel,
rather than because they won't engage. It’s not the worn teeth on the #4 gear
that prevents engagement. The reason the starter does not engage is because
of the spring clip on the #4 gear losing it's tension. The manual calls for about
5 lbs tension required to rotate the clip in it’s groove on the gear. The tension
found on the new ones can be up at about 8 lbs. You will invariably find that
the tension required to move the clip on non-functioning starter gears will be
down to about 2 lbs or less. This can be measured using a fishing scale.
What happens is this.
Because the # 4 gear is light and does not have enough
inertia (resistance to being rotated from a state of rest), Yamaha designed in the
spring clip to increase the inertia. This restrains the gear from turning on the
bendix when the bendix shaft is initially rotated by the starter motor. So, as the
bendix rotates, the helix on the bendix shaft forces the gear down the shaft and
into engagement, because the gear will slide before it will turn. Once it gets to
the end of the bendix, by which time it is fully engaged with the flywheel ring
gear, it has no option but to turn, it has nowhere further to slide. When the
spring tension in the clip is too weak, there is not enough restraint, so instead
of the gear resisting turning, it just spins with the bendix shaft, does not move
down the shaft fully, and is not forced into engagement. It goes down just far
enough to grind off it's teeth against the flywheel ring gear.
All that is necessary to get a starter gear working, no matter how worn the teeth,
is to bend the clip so it gets back to a minimum of 5 lbs required to move the
clip.
All that is needed to do is drain the oil, remove the kickstart lever, brake lever,
foot rest, and disconnect the tach drive cable at the side cover. Then remove the
right hand side cover. The best way is then to remove the clutch basket and
dismount the #4gear from the bike. I haven’t yet tried to do this fix with the
clutch still mounted on the bike and the #4 gear in place, but this may well be
possible. I am pretty sure that on the newer units where the loop of the spring
clip bears against the floor of engine case the that the loop will be visible just
under the forward lower edge of the clutch assembly, and you will be able to
reach in and do the following without further disassembly. On the older units
with the clip with the skinny loop inside the recess in the crankcase, the clutch
will definitely have to be removed and the gear dismounted. In any case, either
way, just use a heavy pliers, like a linesman's pliers, or a Visegrip, to squeeze t
he loop of the clip closed so it bends a little and the clip then grips the gear
tighter. If you do remove the gear from the bike, lever the clip off the gear
using a screwdriver, squeeze the loop of the clip in a vise, and remount it on
the gear. Check the tension with a fishing scale, if it is less that 5 lbs squeeze
the loop a little more.
You can test it immediately, even before remounting the clutch. Pull the spark
leads so the oil-empty engine does not start, and hit the starter button. I bet your
starter will now work, no matter what the wear is on the #4 gear's teeth.
Farrell
See puc.... clip is this then?? Theres no way to squeeze it any tighter so im confused. Lol
I have a 75 and this is the part number thats in mine. This is nothing like any of your two pics.
75xsFLORDIA,
But what I’m asking or saying is, the clip of the puc i sent cant be squeezed so this is not making sense to me. Did u see the pic???
They come pre-made. Search for "Cometic Gasket EC1647032AFM Clutch Cover Gasket Yamaha TX650,XS650 Twin." E-bay - $20.95 with free shipping. Yes, they are expensive but they are steel with Viton coating. Viton material is the little black tip on the needle valves if your wondering.. It's tough and well worth the money. No sealant used and will not stick your case covers on. I got the gasket set for the Yam and the Honda. The dowels let the gasket re-position in the same place and when torqued, not even a seep.
Hi. You said you bought it new in 75. Did you intend to keep it this long or did it grow on you?
