79josh81
Hey guys, quick question about the starter-safety/lighting relay (dual relay) on my 1979 xs650. I tried searching for some answers but I'm looking for more of just a general concensus.
So I have the model with the starter-safety/lighting relay. So if I understand the purpose of this relay correctly:
For the starter - it's suppose to make it so that if the bike is running and you push the start button, the starter won't engage.
For the lighting - the relay cuts power to the head lamp, gauge lights, and high beam indicator light UNTIL the engine is started and running.
The reason I ask is because when I start my bike, the starter works just fine. But if I hit the start button when the bike is running, the starter DOES engage. Also, my gauge lights, head lamp, and high beam indicator light have been out since I bought the bike. Last night I jumpered the relay switch connector and the head lamp, gauge light, and high beam indicator all worked and turned back on.
Is this a pretty good indicator that the starter relay and lighting relay are both not working? I know there's a way to test the wiring to the the relay switch but I'm just trying to get a concensus on whether the symptoms I described are what you would see if the entire relay wasn't working correctly. Just curious if anyone else has ever had one of these go out their bike.
Also, I can jumper the wires to make the lights work like I said above but then I have no starter. If I remove the jumper and plug the connector back in, I'm back to having a working starter but then no lights again. Is there anyway to just bypass the entire relay (starter and lighting) at the same time so I can use the starter and still have lights? If not, is my only option to find a used stock replacement? Or is there some updated way with a newer relay system I can replace it with?
