I have 13+ volts at battery, have not checked voltage at starter, but my lights are very dim indicating lack of voltage from battery. Do you still think it is my starter?
the answer to your question is how could we possibly know ?
You indicate that your battery is fully charged and has adequate capacity to operate the starter motor so if that is the case then it is not the battery at fault.
The fact that you have a dim headlight is probably related to the starter fault and suggests that you either have a
1. bad ground/s somewhere or
2. you have a poor connection/s somewhere or
3. the Starter Motor Relay(solenoid
) is fubar
4. or there is a fault with the starter motor .
5. remote possibility that something is partially seized somewhere
if you asked me to guess I'd say given that you have recently rebuilt the engine etc I would check that all my ground and supply connections are still good especially where they were disturbed or remade. Its an easy check and the easiest place to start .Something could have vibrated loose.
Then I would do the check that Leo suggested .
Take a heavy duty cable like a jump lead or 2.5mm electrical cable and connect one end to the battery + positive and very carefully prod the +positive terminal on the Starter Motor .( Make sure you are in neutral first obviously )
BE CAREFUL to check you are not prodding the negative - ground side of the starter motor or you'll see some sparks and get some unwanted Arc welding experience
Seriously ...don't play around with direct unfused voltage from the battery if you are not completely sure you know what you are doing.
If the starter motor now cranks the engine briskly you have eliminated the starter motor as the faulty component.
No go ? then you'll need to drain the oil and refurbish the starter motor.
Let us know what you have checked what the result was and above all please respond to all questions put or we will not be able to diagnose your fault/s
Remember we are unable to work on your bike directly and rely totally on you for feedback to help us diagnose the fault.
