Why did the original use no heat sink, but the new improved need a heat sink?
...With my official XS650.com yellow meter all those ~.480s read ~.780...
I believe that would be illegal in Canada. Anytime the engine is running, in Canada, we have to have the headlight on. That started around 1978, using the Safety Relay to turn on the headlight, as soon as the alternator produces power. In 1979 Yamaha removed the Headlight Switch from the handlebars.Further info on my rectifier(s).
I retested my spare new one. This and the failed one on the bike had both measured the same on the bench.
With my usual meter:
- Red lead on +, Black lead on the AC terminals. ---, ---, ---
- Black lead on +, Red lead on the AC terminals. ~.480, ~.480, ~.480
- Red lead on -, Black lead on the AC terminals. ~.480, ~.480, ~.480
- Black lead on -, Red lead on the AC terminals. .000, .000, .000
I'm going to call those good.
I don't think it's going to be a problem with the rectifiers themselves. Something has to be cooking them. Either a wiring fault or some other weak component. More testing to follow.
Test #1, battery:
Last night I unplugged the rectifier on my way home thinking the first rectifier had failed to the point of creating a crippling short to ground. With 12.7v at the start, I kicked her over and rode the four miles home. 12.4v when I got there. Then I left the switch on with the headlight on for 25min. The headlight stayed bright and the battery only lost another .5v.
Battery is good, ready to start with Curly's.
Edit: As part of my lighting redesign, I added Pamcopete's neutral switch to the headlight. I'm happy I did. Usually I sit at red lights in 1st, with the headlight on, but it was nice to have the option to save the battery last night. My LED constant-on stalks kept me visible to others while drawing a minimum of current.
Your voltages look normal, except for the 14.65. I suspect you are still using the old original regulator. The 14.65 is too high, and will cause your battery to lose electrolyte. A good regulator will only charge as high as 14.4 volts. 14.1 volts is the preferred maximum.DB , you all have provided great data and info.. Im gonna pass on data which is "good" or "wrong" from my stock electrically 78e that runs well enough it's really gaining my trust.. Yesterdays test results : Engine off, battery 12.62 v , 1thou rpm 12.5 v, 2thou 13.0 v, 3thou 13.5 v, 4thou way up 14.65 v, all stock bulbs,points, &charging system. I expect some variation due to conditions. So there is an example to refer too.. hope that is interesting to you all.. -RT
