Hi DB:
+1 -
I certainly agree with using a torque wrench whenever possible. That is why the Yamaha engineers did the torque calculations in the first place - so that people could know how to do things properly. I also concur that the torque value in the manual should be given as a range, not a single value. Your thought to start at 100 ft-lbs seems to me to be reasonable. As for holding the axle from turning - I have always found that the little screwdriver in the toolkit was adequate. If it won't hold the axle from turning - you may be trying too hard on the axle nut.
The wrinkle is that relatively (
) few people actually carry a torque wrench on the road and yet THAT is where folks often need to remove a wheel to fix a flat etc. (don't ask me how I know that....).
So....what to do without a torque wrench? Well, I would point out that the rear axle
alignment and
attachment arrangements (and both alignment and attachment are vital here) on the XS650 - and all reasonably modern bikes in fact - have a fair bit of redundancy built-in for safety. As for getting the feel of when tight is "tight enough"...you could practice with a torque wrench. As was pointed out above, experienced people sort of "know" how to do this
"tight enough" thing and so it
can be learned with some practice.
OK, lets get back to the bike itself, in order of how you should do the task of
aligning and
attaching the rear wheel, here are the various systems on the bike:
- the chrome chain tensioner brackets and bolts (with attached locknuts) on each end of the swing-arm align and secure the rear wheel - be sure to look carefully from side to side and line-up the marks on the swing arm so that the rear wheel tracks properly behind the front wheel (and the bike doesn't go down the road cocked sideways like an old dog or a poorly maintained dump truck) and also be sure that the chain has the correct amount of slack.
- the pinch bolt on each end of the swing-arm must be loosened when you are moving the axle around and then re-tightened when you are done and getting ready to ride; (NOTE - the stock pinch bolts seem to be rather low grade items so I upgraded to a pair of stronger socket head cap screws (Allen bolts);
- the rear axle nut and threads are large and strong and so if you reaf it up "good-n-tight" with the toolkit wrench (the flat stamped steel thing with the hex hole in one end and the kinked body) and extension tubey-bar thingy - it should be fine (NOTE: you will likely be sitting on your bum on the ground behind the bike at this point and so you could pulled really hard - but don't go crazy on it. However, do give it a good snug-up. Also, this is great time to give the chain a good look-over to ensure that the master link is secure and that none of the other links are rusted or busted.);
- the rear axle cotter pin arrangement is clever because the axle normally has at least two holes drilled through it - and they are offset from the normal 60 deg. hex pattern, so that it is likely that at least one of the holes will line up with one of the castellations (ridges) on the axle nut and you won't have to try too hard to get a pin through the hole. (NOTE: NEVER ride without a cotter pin through the axle - they are very cheap and widely available and should be replaced each time you have the wheel off - or at least every second time. Buy a package of new ones (about $1.00 or so) and stash them in the toolkit bag or inside one of the side covers with some duct tape. Finally, be sure to bend both legs of the cotter pin over to ensure that it stays where it should);
As an old mechanical-automotive engineer, I and the other folks on this forum can assure you that if you do all of that, your rear wheel will remain attached to the bike and all should be well.
Cheers,
Pete
