Did you end up have to drill the throttle shaft screws out?
If you ever have to remove those you will appreciate them. So much easier than the Phillips.replaced them all with hex head
I'm going to reply here to the question about idle speed you asked in a different thread. I don't want to give the guy who started that thread any more advice or help, not even the time of day. He doesn't do any work on his bike, he pays other people to do it. I don't feel this site is here to advise people like that. We turn our own wrenches and enjoy doing so.
Anyway, you've been advised about the evils of idling too low (lack of charging and oil circulation) but not so much about what too high an idle speed can do. Some have told you it's fine but I don't agree with that. The big problem it can cause relates to your ignition timing. The ignition starts into it's advance curve somewhere between 1500 and 1800 RPM. As it advances, the RPMs naturally climb. That induces more advance and more RPM increase. It becomes a self-feeding problem. The RPMs can gradually build up to 2000 or 2500 RPM on their own, without you even touching the throttle.
Now that your carbs have been gone through and are closer to being properly jetted, you found you can set the idle to spec. Almost anyone can get a bike to run hard and fast, WFO as they say. It takes a bit more finesse to get they running well "low and slow", to get a good dependable idle and smooth low speed running. Yes, I think that is a good indication of a good state of tune. Now that your carbs are better, you may be able to reap the benefits of having the timing slightly retarded. In your hot location, the protection against pinging is reason enough to try it. Mine would only ping on really hot days but I'm in the N.E. My "really hot days" are like your "every day", lol.
Daniel......................I think you are misunderstanding some of my statements. The original thread poster, asked if it was OK to idle at 1500 RPM. I said it was fine to idle at 1500 rpm if that is his choice. I said my choice is to idle at 1100 to 1200 rpm. I looked at the question as a straight question...................can he do it or not do it. I stand by what I said...................yes he can choose to do that.Clarification, please:
So, RG, you agree with 5T that 1500 is not ok, and an owner should attempt to correct it so that a steady 1200rpm/13v idle is possible?
That is, 1500 is not just a personal choice and when needed, is an indication of improper settings or undue wear?
I'm not sure how your last posting differs significantly from 5Twins' post. It does, however, seem to differ from your post on the original thread.
And please, gentlemen, when on this thread let's keep discussion to the issue at hand, and refrain from comments about another OP.
This is very interesting stuff, to me at least. I, for one, don't fully understand how to tune and/or troubleshoot these engines.
