XS650D
XS650 Junkie
I have been having over charging problems for a while now on my 77 Standard ever since i installed Mikes Combo Reg/ Rec.It charges at 15.1 Volts and keeps blowing my rear tail light running light.Plus probably baking my new battery and Rotor.I contacted the company that sells the unit and they advised that i prob have a voltage drop in a wire some were,so i went thru the entire harness connections and even changed the key switch but no change.Before i return to the old Reg or get a different Reg (VR-115) i combed the tech section and found an old post stating that on a 77 to check Continuity on the Reg Green wire to Green brush wire,Black Reg wire to black brush wire,Brown Reg wire to key switch Voltage.I have correct 14.5 Volts on Brown with bike running and will not increase so good there,but i get continuity from Green Reg wire to either black or green brush wire and i also get Continuity on Black Reg wire to either Brush wire green or black,Is this correct or is something wired wrong.Thx
Posted via Mobile
Posted via Mobile
