AtoXS
So I was trying to solve the usual left side cover leak. I figured it was the pushrod seal so I replaced that, but the leak persisted. After pulling the cover off again I realized it was coming from the sprocket. The sprocket was super loose so I tighten it up and put the cover back on. I took it for a long ride and it still leaked a ton of oil so again I pull the cover off, this time I pulled the sprocket as well to inspect the seal and this what I found. Surprisingly I've run it this way several hundred miles without any real problems although I also don't know differences I should expect now that a factory sprocket is back on there. I haven't checked to see if the leak is fixed though I doubt it since there was no difference in the thickness of the 510. Anyone ever experience anything like this? It just seemed so odd since I've never really heard XSs being run with a 510 only a 520 or 530.
